Configures the global PIM timers on the specified router interfaces.
| ipv4 | Specifies the IPv4 address family. |
| ipv6 | Specifies the IPv6 address family. |
| hello_interval | Specifies the amount of time before a hello message is sent out by the PIM router. The range is 1–65,535 seconds. |
| jp_interval | Specifies the join/prune interval. The range is 1–65,535 seconds. |
| vlan_name | Specifies a VLAN name. |
| all | Specifies all VLANs. |
These default timers should only be adjusted when excess PIM control packets are observed on the interface.
The following example configures the PIM timers on the VLAN accounting:
configure pim timer 150 300 vlan accounting
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
